Mainboard and not motherboard
brianmanahan
24,635
6,016
What is a mothership Brian?
Nov 8, 2012
20,842
4,785
It's incredibly sexist, why is it not called the Parentboard or Fartherboard? Why do women have to do all the hard work of connecting the different components and looking after them all?
You know if the motherboard were being paid for all of it's hard work it would be the equivalent of a $162,000 salary!
Reactions: Charmonium
ctbaars
1,565
160
We need to ask the French. I think they started this? Maybe not; as a lot of languages around the world put a gender on a noun.
Motherboard makes sense if you consider as that which comes out it, uses female connectors. I don't know. But that gets weird considering that daughterboards plug into the motherboard.
PISTON1246
39
noscopes.boards.net
If it has no vagina then it has no female connectors.
Only among living things do we see actual females or males.
An inanimate object like a computer component is not a female or a male. Not a mother or a father.
Chaotic42
34,899
2,059
Because it's a bad motha... shut your mouth.
I'm just talking about motherboards. Can you dig it?
zinfamous
111,866
31,364
I just hope no one informs this AI of the now-obsolete "Master-Slave" paradigm. Lord only knows what strings of unrelated clauses it will cobble together from the interwebs attempting to respond to that!
BarkingGhostar
8,410
1,617
It is a motherboard since it has slits (or slots) that you push things into and forget to pull back out before something happens.
13,837
In some electronics systems there is even something called a daughter board, and it is usually inserted into the motherboard while other things can be inserted into the daughter board.
giggity.
Reactions: Ken g6
Charmonium
10,555
3,547
It's called a motherboard because whenever something goes wrong and there's no obvious suspect, it's the first thing that gets blamed.
And just FYI, she's f*cking sick of it. OK?
Reactions: ctbaars
