Main site and fourm problems with XP+IE8
Status
Not open for further replies.
jaydee
4,500
4
I've noticed sometimes a page will not load completely with WinXP and IE8: just the header. Sometimes if I hit refresh, it will load completely, sometimes not.
Seems to work fine with WinXP and IE7. IE9 is not supported on XP, so I can't try that.
jaydee
4,500
4
Its looking like nobody cares, but just in case, here are the error details for the forums:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 1.0.3705; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; InfoPath.2)
Timestamp: Tue, 16 Oct 2012 15:28:57 UTC
Message: Could not complete the operation due to error 800a03e8.
Line: 657
Char: 6
Code: 0
URI: http://tags.expo9.exponential.com/tags/AnandTech/ROS/tags.js
CrackRabbit
16,642
62
Why are you still using IE8?
Download Chrome or Firefox or even Opera and use a modern browser. Not only would one of them likely solve the issue you're having but most other web pages would likely work better as well.
jaydee
4,500
4
Work computers still use WinXP, and downloading a browser other than IE is against IT policy. IE8 is end of the line for WinXP, MS won't let you download IE9 or IE10 on XP.
Ryan Smith
The New Boss
Staff member
Oct 22, 2005
537
117
www.anandtech.com
Hi jaydee;
The only real answer I can give you is that the problem is with a 3rd party ad network which we can't control. While we want to make the site viewable for everyone, in a situation like this (where the problem is not local) we're not going to take any steps to fix it right now. IE8 is just too old and the user base is too small.
Sorry.:(
Thebobo
18,574
7,672
We still use XP at work as a lot of businesses do and IE8 at works fine for me at anandtech..Not sure why. But I have problems at home with XP and IE8. I can use chrome just rather use IE the text looks better imo.
Odd thing is at home I have if Chrome open and I am at the Anandtech site IE 8 works fine :confused:
I know you cant do this at work but I think I ended up uninstalling IE 8 to 7 and then to 8 and it worked but I just formatted and now it doesn't work again lol.
There is a setting in IE internet options advanced security that I cant remember but turning it off allowed me to use IE8 with AT fine just that all YouTube videos were black so It has to do something with flash?
Status
