Magnetic reading glasses - What problem does this solve?
Carson Dyle
8,173
524
I was watching a movie last night and saw someone with a similar pair of reading glasses. I'd never seen this before. Note that the glasses also have a strap connecting the two halves, so they're worn around the neck.
Why? Why not unbroken glasses with a band or a chain, like Grandma used to have?
34,834
You don't have to lift them over your head, they can just hang on your neck when not in use.
Carson Dyle
8,173
524
If you wear glasses on a strap around your neck, you only have to put them on over your head once, not when placing them onto or removing them from your nose.
Mayne
8,849
1,380
less wear & tear on the actual solid glasses frame and arms? I have no idea to be honest.
34,834
If you wear glasses on a strap around your neck, you only have to put them on over your head once, not when placing on or removing them from your nose.
<shrug> I worked with a guy who had a pair. It was only thing I could figure.
lxskllr
60,617
10,977
Looks like one of those dumb inventions that only exists because it never existed before, and someone thinks it can make them some money.
PottedMeat
12,363
475
this seems like it probably had a practical application in some very specific occupation and someone thought it work everywhere
Charmonium
10,612
3,595
I think that's the main thing. If you're a woman with carefully coiffed do, these are probably easier to deal with in terms of putting on and taking off. However you have to unhook and re-hook them every time you want to let them down to rest on your chest because on the model I have, the strap is too short to just take them off w/o unhooking.
The other theoretical benefit I guess is that they're not a choking hazard. If by some bizarre twist of fate your glasses get caught in some machinery or something, they'll come apart and not pull you in. Regular glasses with a strap might not even though they're just held together with those little rubber o-rings on the temple bars.
Stopsignhank
2,754
2,253
The contractor that we use has those and it is so cool to watch him put them on and take them off.
OutHouse
36,410
616
jefff Fisher had those on Hard Knox. seemed annoying.
one hand or two to put on glasses? ill take 1.
boomerang
18,883
641
Because the band that goes around the back of your head is integrated into the frames, there is less chance of losing the glasses. Less concern on a job site of a strap that is held onto the temple pieces with friction coming off or catching and breaking with the strap going in one direction and the glasses another. And no, it's not a foolproof solution.
who?
2,327
42
You can pass them around the back of your neck instead of putting them over your head but I'm not sure how often that would be more convenient.
Homerboy
30,890
5,001
I see them a lot on construction sites and/or workshops -- seems to be popular in the skilled trades.
Mike Wolf on American Pickers wears them too. My wife saw them and asked "Magnetic reading glasses - What problem does this solve?" too.
I had no answer.
Cuular
804
18
This also protects your glasses from bending the frames when you step on them after the cat drags them off the bedside table at night.
Reactions: shortylickens
Charmonium
10,612
3,595
Why don't you buy your cat it's own pair? Then it wouldn't have to borrow yours. How do you expect it to keep up with the news and its facespace friends if it has to keep borrowing your glasses? Bad human.
