Magic Cube! Rubix cube revisited :)
Dude... that has to be the most mind numbingly confusing thing I have ever seen. Does anybody actually 'play' this?
Each little cube is a hypersticker.
Each 3x3x3 cluster is a hyperface.
Left-click to twist a hyperface CCW.
Right-click (or meta-click) to twist a hyperface CW.
Middle-click (or control-click or alt-click) on an outer
hyperface to rotate it to center
u -- undo a move
r -- redo a move
S -- scramble 40 moves
shift-1-9 -- scramble by that many moves
s or C -- solve (cheat)
c -- clear (reset to unscrambled state)
o -- toggle outlines
- - decrease puzzle size (minimum 2x2x2x2) and reset
+ - increase puzzle size (maximum 6x6x6x6) and reset
Hold down one or more number keys while left- or right-clicking
to alter which layers are twisted (default is '1',
hold down '1','2','3' simultaneously to rotate the whole puzzle).
For more information, see http://www.superliminal.com/cube/cube.htm
You are visitor 6686 since Sat Apr 27 20:14:14 EDT 2002 .
Last Modified: Thu Apr 25 00:04:02 PDT 2002
Back to Don Hatch's home page.
u -- undo a move
r -- redo a move
I can safely say that this is way beyond me
Originally posted by: boi
I'll give 500 bucks to anyone that can do it.
I just did it
Screen cap
"Don and Jay were the first to have solved the puzzle making extensive use of the move macro facility in the UNIX version. Recently, Roice Nelson became the first person to solve the puzzle without using macros. For his solution, he extended Philip Marshall's 3D "Ultimate Solution to Rubik's Cube". You can learn Roice's solution if you don't feel like trying to solve it yourself first. Using his techniques, Roice and others have continued to find ever shorter solutions so that the record currently recovered by Roice required only 495 twists! "
So it took you more then 495 twists, or did you beat the record?!!!
I just did it
Screen cap
Yeah, my wrist hurts now.
You all are a bunch of liars. You just had the puzzle "Solve" itself, and now are claiming to have done it yourself.
By the way, I REALLY DID solve it. PM me for a Screen Cap 😀
(I didn't really, don't PM me.)
KeyserSoze
