Mag LED flashlight is really good
OS
15,581
i just got a two AA mag LED flashlight from Fry's. It's really bright and the light pattern is fairly even. Plus it's only $22.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
I got 2 of the LED conversion kits ($7 IIRC) for my AA maglights. They are now insanely bright.
jpeyton
Moderator in SFF, Notebooks, Pre-Built/Barebones
Moderator
Aug 23, 2003
25,375
142
That's cool, but a StreamLight Propoly will probably kick your Mag's ass.
Of course they'll seem insanely bright compared to your old incandescent Mag.
mugs
48,920
46
I had the 3-AA version but lost it. :| My main complaint about it was that focusing it would increase the intensity of the beam at the center, but the overall size of the beam stayed the same... I guess I could see a use for that, but I could also see a use for concentrating all of the light in the center, which you can't do.
jpeyton
Moderator
Aug 23, 2003
25,375
142
OS
15,581
http://www.flashlightreviews.com/reviews/streamlight_4aaled.htm
http://www.flashlightreviews.com/reviews/maglite_minimagled.htm
they say the mag led has more output, hahaha
:roll:
This Propoly junior.
the mag still has a higher output, ahahahaha
jpeyton
Moderator
Aug 23, 2003
25,375
142
:roll:
Oh dear. You really are a gentle retard when it comes to flashlights.
Please Google voltage regulation, and come back with a few points added to your IQ.
The Streamlight has a flat output curve for the first 3.5 hours @ 80% output. The output of the Mag dips below 80% output after 30 minutes, and drops output 5% every 30 minutes after that, draining completely after about 3:45. The Streamlight will provide a small amount of useable output even after 8 hours.
Even though the overall output of the Mag is 10% higher than the Propoly at full charge, that only holds true for the first 30 minutes. But the throw of the Propoly (think fog cutting), is roughly 60% higher than the Mag.
Don't try to comprehend all of that at once. Save some for the morning.
0roo0roo
64,795
84
yea i read the mag led is a poor design, it has to limit output due to heat or something. meh. compromised design to fit the original bulb size.
