- Feb 8, 2001
- 35,461
- 4
- 81
Originally posted by: Platypus
There are better starter packs out there, if you end up with the epi you should replace the pickups and the tuners at the very least.
Tone whore![]()
Originally posted by: se7en
I started on one and they are just fine. Epi was bought out by gibson long ago only differece is the quality of material and where its made.
I had mine for 7-8 years with no problem at all.
What's a better starter pack, wanted to stay under 300?
What kind of music do you want to play? There are lots of starter guitars out there and they all sound different and make different tones. In that price range it's going to be a question of picking the one that sucks the least unfortunately.
Originally posted by: paulxcook
I am against starter packs. Gear holds up well over time, find some quality used gear and you'll be happier.
For what reason on a starter guitar, I seriously wouldn't waste the money?
An epi can be a good starter, but I have heard the latest models have gone downhill esp compared to what's out there. You can shop kits until you go crazy though...there is always a deal out there. I'd say find used though...check colleges esp the music dept., Craigslist, any instrument shop in your area, even ebay can turn up great buys...
The thing with any guitar, the cheaper you go the more variable the sound and feel between each can be.
I'd want to be able to try it out unless I had found a great deal on a vintage instrument and have someone much better than me play it as well to give me a critique.
All in all though your starter guitar should never be the one you will go the distance with. You will make mistakes that damage it, find things that are important and not so important to you, figure out what a good fit for you/playing style, etc....
Once you figure out you want to keep playing upgrade rather than pour money into a starter. I used a $150 plain jane electric I found on sale at a local shop. It was a no-name type of brand but it felt really good and much better guitarist really liked it's action and playablity. I ended up selling it for $175. My next guitar was a Martin HD28.
I sold that guitar for more than I paid as well, wish I didn't have to at the time though.
Originally posted by: Rudee
Go buy a used RG 500 series or higher guitar. They're pretty darn remarkable, especially if you change the stock pickups.
Starter kits have major issues because the same idiots like here are comparing them to guitars that cost a multiple of what the entire kit runs.
Like I said, all starter kits suck. For a little over a hundred extra bucks you can turn a shitty guitar into a formidable learning instrument by replacing the pickups for ~90 bucks and tuners for 15 or so. I wouldn't really call that 'pouring money' into it. Starter kits are perfect for someone like the OP who is interested in getting back into guitar or just starting out who have no idea what they're after guitar wise and don't want to sink a lot of money into something that might not pan out. Furthermore, CL and local music shops are filled to the brim with people trying to off faulty gear on people who have no idea what to look for.
Is it possible for you to reply to a thread without resorting to name calling when you disagree with someone? :roll:
Originally posted by: hellokeith
If you are only playing by yourself, then you'll be fine.
If you ever plan to play w/ a band or play live, disown all knowledge of owning any of this equipment less you be mocked back into the stoneage.
