I'm not sure if this is related to the Win98SE shutdown problem. I can't access the MS site for some reason. Anyway, here is the problem.
If you shut down the computer it stays off for a couple of seconds and then repowers itself. It does the same if you power it down via the power button. I've got all power management disabled in Windows and in BIOS.
I had this system on my bench for weeks. While it was there I ran benchmarks, installed programs, defraged, and frequently powercycled it as part of a normal routine to help insure that it was functioning properly. The only thing that changed from when I had it on my bench to now is that it is now using a USB mouse instead of a serial mouse.
This system is completely stable except for this issue.
The system is:
-Gigabyte 6vx7-4x w/ latest drivers
-cel366@550
-64mb generic pc100 cas3
-tnt2 8mb vanta agp vid card
-sonic impact s100 pci sound
-20gig WD 7200rpm ata66 HD
-Logitec USB mouse
-Aztech USB modem
Thanks in advance for any suggestions.
The system is:
-cel366@550
-Logitec USB mouse
-Aztech USB modem
