I have built a new system right around New Years. Mobo is Asus A8V Deluxe, CPU is AMD64 3400+. 512 megs (1 stick) of Ultra PC3200 RAM. The first time I went to power it up the system would not boot and I got the voice POST message that the "system failed due to CPU overclocking". This was before the system had ever booted, so there was no possibility of overclocking. This message continued until I changed the memory location on the mobo. Then everything booted fine, no more problems.
However, I have been periodically getting blue screens with the deadly "Machine Check Exception" error. After I reboot from one of these errors I am forced into BIOS because no hard drives are detected! Once in BIOS the hard drives are detected again and I can reboot back into Windows. (I am running XP Pro.) This has happened perhaps 4 or 5 times over the last month. There is no consistent activity occurring when the errors happen. Most of the time I find the blue screen in the morning. This morning I had a blue screen. When I rebooted I got the "system failed due to CPU overclocking" error again. I powered the system down completely and let it sit for a few minutes. When I powered back on I was able to reboot (but I had to reset the hard drives in BIOS still, as described above).
So my question is: WTF? If I had to guess, given the evidence here, I would say that this is a mobo problem. But the symptoms are so odd. Can anyone add a perspective here to help me out? This should be a fast stable system, but these problems are beginning to worry me. Whose hardware should I blame?? Thanks for any and all help.
