Macbook replacement
TreVader
2,057
I'm considering a 256 or. 512 GB SSD to put in my mid 2010 (last ever made) 13" core 2 duo MacBook.
Koing
Elite Member <br> Super Moderator<br> Health and F
Oct 11, 2000
16,843
Finally pulled the trigger. Got the rMBP 13 with 512GB. Decided I could wait on the 16GB of ram. I think 8GB should be plenty for my needs. 4GB doesn't cut it though. I've been on the fence since Nov about the rMBP, deciding when to get it. Then I was tossing up the 256 or the 512, and decided, f0ck it, drop another £200 for it. It'll be okay in the long run. I'm already struggling with 256GB. It's no point spending all of that money and then to be still struggling with hard drive space.
Just seen your sig and it's your 3rd laptop. What do you do with the C2D machine?
Koing
TreVader
2,057
Koing
Right now I'm using it to play movies with the mini-DP out I already upgraded it to 4GB a long time ago. It makes a pretty decent web browsing and media playback machine and it does run mavericks.
Koing
Oct 11, 2000
16,843
I see. I probably wouldn't bother then if it's not your main machine, unless you have a spare £80 burning a whole in your wallet for a 256GB one :p
Koing
TreVader
2,057
Koing
I'll consider it, let me talk to my gf she's the one who decides what I'll be doing with tha C2D machine.
I'll get back to you.
Koing
Oct 11, 2000
16,843
So the rMBP is your daily machine? The MBA is your ultra portable and the C2D is for media? Wouldn't the MBA be easier to use for the media as you only need one HDMI cable? I have the mini display port to DVI adapter and a optical out to my receiver. Luckily my receiver has 2 opticals. A lot of receivers now a days only have one optical. My last one had about 2 or 3 but it was from 2008.
I don't think you'll really need the SSD for media IMO. The biggest gains with the SSD are for system responses and if you transfer a lot of big files.
Koing
sze5003
14,196
634
I'm looking for a used one somewhere. I want to put a 256gb ssd and 8gb ram in it too. Microcenter has one for $800. 8gb ram would cost me about $80 from Amazon and if I can snag a 512gb ssd for my desktop I'll stick the Samsung 830 in the laptop. Finding a good deal on a Mac is tough. How are are the refurbished models?
I mainly will use it around the house and for development which will probably different coding than I do at work..android, php, java, python. I like learning new things.
TreVader
2,057
Koing
The MPB is my work machine. I use the MBA for home and trips but I don't pay for cable TV just FiOS so I kinda use the C2D as a cable box to jack FiOS TV because my bro has an acct he doesn't use. It's also default GF machine if she needs to use word or photoshop.
I think the P8600 is only maybe 20-30% slower than the sandy bridge i5 in my MacBook Air. If it had an SSD I think it would be a much more usable machine but it's a great machine runs mavericks fine
Koing
Oct 11, 2000
16,843
I see.
My C2D 2.1, 4GB would CHOKE on youtube :(. It would also choke on some 1080p rips but would incredibly play them smoother than youtube 720p :(.
Now to sort out my rMBP settings and get all of my stuff from the C2D machine across.
I thought the scrolling was 'okay' on my C2D and now that I'm on a modern machine (haha) the screen is just terrible and the scrolling is really choppy. It's amazing what you don't notice when you don't have access to a faster machine.
Koing
Eug
23,790
1,361
I see.
Really? My C2D 2.4, 4 GB white 2008 MacBook works fine on 720p YouTube, and also plays 1080p rips OK. However, it does it with vacuum cleaner fan mode, and eats battery. Totally stresses out the CPU I guess.
Meanwhile my slower clocked C2D 2.26, 4 GB aluminum 2009 MacBook Pro works perfectly with everything, ultra smooth.
That GeForce 9400M GPU really makes a huge difference. I'm not complaining about the white MacBook too much though, since it's a kitchen/living room machine only, and it only cost $400 used (plus SSD and memory).
Koing
Oct 11, 2000
16,843
Yes my white C2D 2.1 4GB 256GB SSD would choke on youtube at times. It will play rips fine for the most part but it would stutter at times which was really annoying. Yes the fan is really blowing hard as well. Yeah the graphics is much better on your MBP.
My dam qnap (TS 210) doesn't work with mavericks for Time Machine :(. I've already spent about 3hrs trying to get it to work and there are issues with it and Mavericks. It would work fine on 10.6 on my C2D.
I've taken out the SSD from my C2D and transferred pretty much everything to my rMBP now. Only a few small things. Then to sync my iPhone 5 to this rMBP.
Koing
TreVader
2,057
Koing
This is surprising because I can attest that mine is fine with 1080P .mkv playback and streatming/netflix
TreVader
2,057
There must be some kind of architectural difference between the 2.26 in the MBP and the 2.4 in the MB
The 2.4 in my Macbook (a 2010) should be faster than a 2.4 from 2008, I haven't checked the ark but I'm pretty sure there are some difference between older C2D and newer.
postmortemIA
7,721
40
Flash can be hardware accelerated, but you have to have certain GPU. Does choking one have integrated graphics?
TreVader
2,057
Good point, the 2010 macbook has a geforce GT320 but it's at least somewhat integrated because it has no vram
What does the 2008 macbook have?
Koing
Oct 11, 2000
16,843
Intel GMA X3100 with 144MB of RAM which is shared with main memory. I guess if you bought it used in Spring 2008 it could be an Intel GMA 950 card, which only has 64MB of RAM.
It's the very weak graphics card.
Do you guys use the official apple time machine or do you use a NAS that is time machine compatible? I've had NOTHING but trouble with my qnap TS 210 ever since I got it :(
Koing
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
Koing
Oh yea, both the x3100 and the GMA950 (were they really using it for almost 2 years? My '06 OG MacBook had a 950 in it.) were fairly weak. The nVidia cards were tons better, which is why my 2010 11" Air could actually do stuff even though the CPU was weak.
Eug
23,790
1,361
Yep. For integrated Intel GPUs, X3100 is the one you DON'T want.
GMA X3100 = no significant GPU acceleration for H.264 video. That is what is in my 2008 MacBook.
GMA 4500MHD = full GPU acceleration for HD H.264 video. That is what is in my el-cheapo Acer.
In 2009, the MacBook got the GeForce 9400M, like what my 2009 MBP has.
Koing
Oct 11, 2000
16,843
So basically if I had waited another year or so I'd have been okay :p
I got to say this rMBP is very nice to use. The keyboard feels a lot nicer, not that the old one was bad on the MB. Just that it had 7yrs use.
Koing
Eug
23,790
1,361
Yes, and also, the 2008 MacBook only supports up to OS X 10.7 Lion.
The 2009 MacBook (and my 2009 MBP) supports even OS X 10.10 Yosemite, presumably because of the GPU again.
That's annoying to me, because Lion is buggy IMO. I would have preferred at least 10.8 Mountain Lion support.
TreVader
2,057
I think it's the lack of unified shaders on the GPU parts to those models. I am happy that Yosemite will support my mid 2010 I really got screwed on that one with the release of the core i5 MBA.
Koing
Oct 11, 2000
16,843
I think I had 10.6 on my C2D and it was okay for my needs.
I think I'm going to get a second hand time capsule as my dam qnap TS 210 has stopped working with time machine :(. I've been reading the forums for hours trying to find a solution :(
Koing
