Macbook [Pro] options worth it?
JF060392
348
I am considering getting a macbook pro 15" at the moment and I am a physics major. this will be my first mac and i am debating whether or not to get the high resolution screen and 7200 rpm 500 gb hdd. Is this worth the $2000 it will cost?
Patranus
9,280
Things that cannot be upgraded later.
IE: screen and CPU
My current MacBook Pro is the best laptop I have ever owned.
(I say that about every new Apple laptop I buy)
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
Like Patranus said, if you want to upgrade the drive, you can do it later, for cheaper, and keep the old one as additional storage.
The screen you cannot upgrade yourself, so why not get the higher res?
secretanchitman
9,353
23
get the higher resolution screen! you can upgrade the hd to whatever you want (the new seagate momentus XT looks amazing).
silverpig
27,703
12
Go with the screen, skip the HD. If you want to upgrade the HD, I'd suggest getting an aftermarket SSD. Super speedy, and it's not like you really carry around 1 TB of movies on your laptop anyways. Then use the current HD in a small USB enclosure for storage/time machine.
MovingTarget
9,002
115
Don't skimp on the screen if you have the disposable income to afford it. You can upgrade the drive and RAM later.
mmntech
17,501
12
IE: screen and CPU
This. If you can afford it, sink your cash here. Apple wants too much for memory and HDD upgrades. It's vary easy to DIY.
TheStu
Moderator
Sep 15, 2004
12,089
45
that all depends on the case you have. even my brother's dell was simple.. remove side, unplug two cables, swap. toolless.
Certainly easier than my tower.... remove side, unplug existing drives, remove front of tower, unscrew cage on both sides, slide cage out, slide drive into cage, screw drive into cage
But I don't have to do drive swaps all that often.
