manlymatt83
Hi all,
Three year old MacBook Air (early 2014).
*IF* and only if I can get the battery to charge up to 100%, it charges veryyyy slowly. But once it's at 100%, it drains normally until 47%. Then the computer becomes very unreliable on battery power -- normally just shutting itself off hard. If I can get it to turn on without plugging it in, it'll usually shut off a few minutes later randomly even if the battery is still around 45-50%.
Most of the time, I have to use the laptop with the wall charger. For example, right now I have it plugged in. The battery says 47% but the message "Battery is not charging" appears when I click the status icon at the top right. If I were to unplug the laptop from the wall right now, it would immediately shut off -- no clean shut down.
However, yesterday I was traveling and plugged the laptop in at a Starbucks and low and behold it went from 47% up to 95%... same charger. Seems to work sometimes, not others.
Any thoughts on this? I hesitate to say it's the battery that needs replacing because the battery charges sometimes and not others, and the health of my battery is "good", cycles only 475. I have also tried multiple wall chargers so I know the problem isn't that either. If this is a motherboard issue, I'll probably just grab a new MacBook Air.
Thanks!
Thanks!
