Mac-style Menu Bar for GTK and Java/Swing applications!
That is what I've been trying to get installed on my Ubuntu setup. Yes, I know it's just 'eye candy' and all but I think it's slick looking and want to try it. Has anyone else tried it and had success? I tried it without success so far. I've posted a few times in there if you want to see my replies.
EDIT: Okay, I want to list what I've done and what happens. My setup is Dapper 6.06 fully patched/updated running Gnome.
Edit2: Figured out how to prevent the gnome-panel looping but the Mac-style menu bar isn't loading. I apply the .deb file, kill gnome-panel, and restart gnome-panel. It reloads but it's the same default panel rather than the Mac-style I'm trying to install. I posted my ~.xsession-errors a few posts below.
- 1. I downloaded the .deb file from the thread I posted above
2. I did a 'dpkg -i libgtk2.0-0_2.8.20-0ubuntu1_i386.deb'
3. It ran for a short bit and finished with no output/errors
4. Rebooted
5. When my gnome-panel launched I saw the bar at the bottom but it didn't finish and I got into a loop of messages saying gnome-panel detected a panel already running and was exiting. All I could do is ctrl-alt-f9 out and I think I did 'sudo gdm stop'
6. I did apt-get update & apt-get upgrade and it said libgtk2.0-0 2.8.20-0ubuntu1 needed updated. I allowed it to update.
7. I did a gdm restart and was able to log in and got my desktop but with the regular gnome-panel menu bar at the bottom (not sure if it matters but I use only 1 panel instead of the default 2)
