Essence_of_War
I've got a Mac Pro 3,1 that I want to add more RAM to, to try get another year or so of use out of it.
I found this item:
http://www.newegg.com/Product/Product.aspx?Item=9SIA7S63636776
Which claims it is compatible only with Xserve 2,1, but all of those RAM specs: FB-DIMM, 1.8V, PC2-6400, are the exact specs of RAM for the Mac Pro 3,1 as well.
Is this likely compatible?
I found this item:
Code:
[U][B]Brand:[/B][/U] Nemix RAM
[U][B]Capacity:[/B][/U] 8GB (4 x 2GB)
[U][B]Frequency:[/B][/U] 800MHz
[U][B]Speed:[/B][/U] PC2-6400
[U][B]Pin Count:[/B][/U] 240-pin
[U][B]Voltage:[/B][/U] 1.8V
[U][B]ECC:[/B][/U] Yes
[U][B]Reg/Buff:[/B][/U] Fully Buffered
[U][B]Ranking:[/B][/U] 2R
[U][B]Organization:[/B][/U] x8
[U][B]Type:[/B][/U] FB-DIMM
[U][B]Compatible With:[/B][/U] Xserve Quad-Core Xeon 2,1 2008
