M2 screw for Maximux X, how it's called?
xsoft
14
Hi Guys,
during my SSD-Nvme installation, i've lost one screw.
I tried to search in on Ebay, without any luck.
can somebody help me find it? ebay would be great
here how's it looks
LTC8K6
28,520
1,576
No, they are not these..
the one's I have are narrower.
Hardware store will likely have a device that will match the screw size and thread. All of the stores near me have it. Metric too.
xsoft
14
so i've back with photos, and as you'll see it is none of the options you suggested.
Mr Evil
464
187
mrevil.asvachin.com
They look right.
7mm is an unusual size. I expect that it's nominally 6mm, and longer than that due to manufacturing tolerances. When you screw it in, does it go in by >>1mm? If not, you might actually need a 7mm one.
xsoft
14
no, they actually a perfect fit when i close one.
so frustrating those irregular screws. it actually SCREWS me over.
