M-Audio Revolution 7.1 Sound Card - Possible to get mp3's to play via Digital Coax?
Excelsior
19,047
18
If the receiver has digital coax input..sure..
Was that a smart ass answer? I dunno...no clue.
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Originally posted by: RanDum72
Does the receiver have a digital input?
Yes (this isnt for me, im asking for someone else who has the card)
But no sound comes out when he plays an mp3 though digital coax into his reciever....
RanDum72
4,330
I don't what the options are for that sound card but make sure the digital output format is PCM. Maybe the card (or the software/drivers that come with it) has an option to enable/disable digital out.
Isocene
694
I do the same thing with my mobo, it has a digital coax out. It works fine. Make sure the setting on the reciever are right for one. Sometimes you have to flip through the possible digital audio inputs until you hit it.
Also, like RanDum said, make sure its set to output to digital out.
Good luck! When you get it working it will sound great. Next you have to run an svideo cable to the receiver and you are all set!
Algere
2,157
What about sound formats other than MP3?
