- May 14, 2014
- 3
- 0
- 0
Hi All,
I purchased a home built around 2000. It has a Lucent Tech HomeStar System installed in it that no longer has any info on it. Kind of a noob with this stuff so bear with me. It has Cat5 (voice and data) and Coax throughout the house that terminate in a panel in the laundry room. See attached pictures. I naively thought the comcast installer would hook up the new router, voip, and cable to the system and everything would just work. Not the case.
First the coax cable - he said he could not just connect the cable modem with a coax cable directly to the panel with all the existing coax cables connected. With so many splits the signal would be too weak according to him. So we identified a few rooms found the cables and just connected them via a four way splitter.
Second the RJ45 data - he didn't connect any rooms. He said I could go through the cables individually and hook up to 4 different outlets to the back of the cable modem or get a switch for all. To me I thought the whole board was a switch to plug into but held off in case he didn't know what he was talking about. In the meantime he said just use the wireless from the modem.
Last Voice - we just picked one location in the kitchen, found the connection in the panel and plugged phone cable from the cable modem into that spot on the panel.
What do you guys advise on getting this system really up and running? As far as the coax cable panel. Is installer right that I can only split signal up to four was or does my panel have a booster inside it that can handle all the connections? As far as data, I shouldn't need a separate switch to patch into, it looks like I need to find the incoming connection to just plug into to activate all the connections. Voice, I'm not sure on where to plug that one in.
I definitely need to buy a tool checking the Cat5 cables to make sure they are wired properly and double check which rooms/outlets they terminate to. I also need a Coax tester/checker to do the same thing. Comcast guy had one but forgot to ask.
Thanks so much for your help in advance! Maybe I need to get a professional out here and in that case, I live in Palm Beach Gardens, FL for any references.
Chris
Chris
