- May 19, 2011
- 21,002
- 16,247
- 136
I've been using it for a year and a half now and this weird little problem just came out of the woodwork and I have no idea what might have caused it.
I have my own server (web/mail/other stuff) on my LAN. I have TB set up to check mail with it and I also pick up my calendars off it. Recently TB has started reporting 'connection refused' for it, and will do this for approximately a minute before inexplicably deciding that it can actually communicate with the server.
During this minute-or-so, telnetting to the server's hostname or IP on mail ports results in a timeout. Internet access works fine.
telnet says:
I think the issue isn't intermittent, I'm not 100% sure though. Booting from cold or a reboot doesn't seem to make any difference. One time I booted into Lubuntu, left it on the login screen for about half an hour, then the problem occurred after sign-in. However, signing out and back in again doesn't seem to trigger the issue.
Nothing interesting in dmesg that I can see. I've tried dropping/resetting the firewall (ufw), no difference.
Ethernet connection coupled with mains networking.
telnet says:
Code:
Trying 192.168.0.7...
telnet: Unable to connect to remote host: No route to host
