Lube, Oil and Filter...
BigToque
11,700
I know when you go to get your oil changed, they drain the oil, put a new oil filter on and put in the new oil.
What the heck is the "lube" part though?
BigToque
11,700
Originally posted by: Nebor
That's for the billing phase.
I've always been charged only a buck or two more to have it changed at a garage (as opposed to doing it myself), which is fine for me because then I don't have to take the time to haul off the old oil to some disposal site (which is usually the garage anyway).
Nebor
29,582
12
Just a joke, my cars go to the dealerships for everything.
iamwiz82
30,772
13
So nobody knows?
Chassis & suspension lube. Most cars nowadays have no-maintenance joints and dont have zerks. I prefer to put aftermarket bushings with zerks built-in, however.
Rumpltzer
4,815
33
Yeah, I'm not sure what a zerk is, but my truck had these little nipples for injecting grease into the steering linkage and some suspension points. I've always assumed that that is the "lube" part.
I own a grease gun. I can lube your nipples for free if you want. :p
iamwiz82
30,772
13
That is a zerk.
Nebor
29,582
12
That is a zerk.
Note to self, getting zerked involves having your nipples greased.
