- Oct 23, 2000
- 9,200
- 765
- 126
We have a family cabin in a fairly remote area in the mountains in northern Utah. The location is inside Verizon's advertised coverage area, but not by very much on one side due to tall hills and deep valleys. (edit: The 'blocked' area is to one side about a mile away and not directly between the tower and the cabin). We can usually get a pretty decent LTE signal up there with speeds tested around 12-15mpbs by putting a cell phone in the window facing toward the nearest cell towers about 22 miles away in Evanston, Wyoming, and use the mobile hotspot on that cell phone to provide Internet access for laptops and other devices inside the cabin. It's not totally reliable, and sometimes there isn't a signal at all, but it's usually good enough to check in with email, texting, and maybe a bit of mobile gaming.
However, in the last few months the service quality has degraded significantly, to the point where we often can't get any signal at all, and a lot of the time when the phone in the window does show an LTE signal, it still doesn't have any actual Internet access. I've spent many hours waiting on hold and eventually talking to a few Tier 2 and Tier 3 Verizon techs who say that they agree that the signal may be intermittent depending on weather and other conditions, but that we definitely should be able to get a usable signal in that area, so they suspect that the tower we are using is simply overloaded with all of the people working from home.
The signal actually started working really well a few hours after my last round of repeated calls to Tier 2/3, so they might have done something to fix a problem on the tower, or it might have just been a coincidence. I'd still like to try to do something to make the signal more stable and reliable if possible.
Since Verizon no longer sells 4G/LTE signal boosters directly, they were not able to give me any recommendations for specific devices, or even that I should use one at all. So now I'm asking for help from people who don't have to directly represent Verizon.
The Verizon store in Evanston told me that they used to sell this model to rural users in the area so they recommended that I give it a try, but it's pretty expensive to just "give a try" so I'm hoping for personal experience with it - or a different signal booster - in a rural environment. https://www.weboost.com/products/home-multiroom The online reviews that I found do seem to be pretty good, but there aren't very many of them...
I don't really need the multiple room indoor coverage, but the increased range/signal boost from the tower over the single room model does seem worthwhile in my situation.
