I've been trying to find the lowest power external hard disk drive that works with a phone using USB OTG. I need lots of portable space and a flash drive is too small.
My WD My Passport 1TB works with my Lenovo Windows tablet using an OTG cable but it doesn't work with a phone, there's not enough power to properly initialize the drive. WD specs show that the Passport needs 650 mA to run whereas most phones only give 500 mA through OTG. A card reader with a full sized SD card works fine.
I then thought about making my own portable drive. WD 2.5" Scorpio Blue drives use 1.5-1.9 W for seeking or max 380 mA. A cheap USB2-SATA casing should add 100 mA. Total current should be under the 500 mA limit on most phones. I wanted to find out if anyone else has done this successfully.
