The equation for conduction is very simple:
The heat loss rate Q/t = [(kA(Thot-Tcold))/d] where Q/t is heat transfer rate (BTU/hr), k is the heat transfer (conduction) coefficient, A is the surface area, T is the temperature and d is the thickness of the conducting material. For compound materials you can solve simultaneous equations or calculate homogenized coefficients. As you can see, the only variable in the problem you posed is the temperature inside the freezer.
Freezers have constant speed, constant condition compression refrigeration cycles so they operate at essentially constant efficiency and cycle on and off. Therefore, the energy used is directly related to the heat transferred into the freezer.
Convection and radiation equations are very complicated but don't really enter into this problem. The flow around the freezer is so slow and the surface temperature so close to ambient we would usually approximate convective effects by a "surface conduction coefficient".
