Lower Processor Speed :Dell Charger Issues
rezurect007
My Windows Experience Index Processor score after a fresh install was 6.7 before driver installation, after driver installations its reduced to 3.2.
Did a windows reinstall again and the score 3.2 remains, I`m guessing its a faulty driver.
Uninstalled:
Intel turbo Boost monitor and Intel management Interface
Processor score reaches 5.0. Still not at 6.7 which i got before any driver installation at all.
Any Recommended tool to check throttling and other proccessor problems?
Face2Face
4,100
215
What type of CPU is it? BTW WEI scores are pointless.
Is you system running slower than usual? Download CPU-Z and Realtemp to monitor your CPU.
rezurect007
Core i5 450m 2.4Ghz
Code:
CPU-Z TXT Report
Binaries
CPU-Z version			1.63.0
Processors
Number of processors		1
Number of threads		4
APICs
Processor 0
	-- Core 0
		-- Thread 0	0
		-- Thread 1	1
	-- Core 2
		-- Thread 0	4
		-- Thread 1	5
Timers
	ACPI timer		3.580 MHz
	HPET timer		14.318 MHz
	Perf timer		2.338 MHz
	Sys timer		1.000 KHz
	BCLK timer		133.03 MHz
Processors Information
Processor 1			ID = 0
	Number of cores		2 (max 8)
	Number of threads	4 (max 16)
	Name			Intel Core i5 450M
	Codename		Arrandale
	Specification		Intel(R) Core(TM) i5 CPU       M 450  @ 2.40GHz
	Package (platform ID)	Socket 989 rPGA (0x4)
	CPUID			6.5.5
	Extended CPUID		6.25
	Core Stepping		K0
	Technology		32 nm
	TDP Limit		25 Watts
	Core Speed		1197.2 MHz
	Multiplier x FSB	9.0 x 133.0 MHz
	Rated Bus speed		2394.3 MHz
	Stock frequency		2400 MHz
	Instructions sets	MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
	L1 Data cache		2 x 32 KBytes, 8-way set associative, 64-byte line size
	L1 Instruction cache	2 x 32 KBytes, 4-way set associative, 64-byte line size
	L2 cache		2 x 256 KBytes, 8-way set associative, 64-byte line size
	L3 cache		3 MBytes, 12-way set associative, 64-byte line size
	FID/VID Control		yes
	Turbo Mode		supported, enabled
	Max turbo frequency	2666 MHz
	Max non-turbo ratio	18x
	Max turbo ratio		20x
	Max efficiency ratio	9x
	TDC Limit		25 Amps
	Core TDP		25 Watts
	Uncore TDP		0 Watts
	Power @ 9x		3 Watts
	Power @ 10x		4 Watts
	Power @ 11x		5 Watts
	Power @ 12x		7 Watts
	Power @ 13x		9 Watts
	Power @ 14x		11 Watts
	Power @ 15x		14 Watts
	Power @ 16x		17 Watts
	Power @ 17x		21 Watts
	Power @ 18x		25 Watts
	Max bus number		255
	Attached device		PCI device at bus 255, device 2, function 1
tweakboy
9,517
www.hammiestudios.com
Those WEI scores dont mean jack!!!!!!!!!!
Explain this. My dad on Win7 used to get 360mbps, then its health went to 96 percent and transfered like 285 or 300mbps. His score was 7.5 ... My score was 7.3 , I am 541mbps .... with 512k sector. and got 7.3 . However at that time even with my q6660 my rig was much faster then his. Boots up soo much faster launches apps faster,, and is noticably much faster, but I get . Also firmware updates speed up this thing to have one of the highest seq read on single SSD. anyhow, let me know. gl
tweakboy
9,517
Unless your moving Gigabytes of data everyday then RAID it,,,, other then that forget rAID,
grab a sammy or crucial and your set. Really consider 512GB,, you wont be sorry man. gl
rezurect007
It turns out that the the cause is not the drivers, its Hardware. Ive thought i had a problem with my power adapter, error message shown below, (I actually tried another adapter it showed the same error message shown below,so it wasn't the power adapters fault), but never bothered to find the cause coz i charge to 100%(a bit of twisting,force and reconnecting the adapter a couple of times usually fixed the error message,Now even that doesn't seem to work) and disable battery charging from dells panel. I mostly run on AC power. Just realized that it actually effects CPU core clock.
CPU: Corei5 @2.4 Ghz
CPU Z Screen shot for Core Speed
Without AC connected.
The message i get when i plugin my AC adapter.
With AC Adapter:1.2Ghz
Essentially, i cant charge my Laptop,coz from a bit of googling i find its most probably the solders came off and Power jack is loose on the motherboard.
And i cant operate it on battery coz i cant charge it.
On AC my my core clock is @ 1.2Ghz.
It seems to be a very common problem with dells.
http://www.laptop-junction.com/toast/content/dell-ac-power-adapter-not-recognized
http://en.community.dell.com/support-forums/laptop/f/3518/t/19245752.aspx
http://en.community.dell.com/support-forums/laptop/f/3518/p/19255676/19421247.aspx#19421247
No warranty. So dells service center wont help me.
The suggested fix seems to be to re-solder 9 or so power jack connectors on the motherboard.
I haven't done a tear down before, and it seems like i have to take the entire thing apart to get to the Power jack.
Posting links which might be useful for anyone having the same problem.
Model Dell Inspiron N5010
http://www.insidemylaptop.com/taking-apart-dell-inspiron-n5010-inspiron-15r-laptop/
http://www.youtube.com/watch?v=WaO4weIV7OU
http://www.youtube.com/watch?v=_WDvZpn5fMM
Solns:
http://www.ebay.com/itm/CN-0WXHDY-I...t=LH_DefaultDomain_0&hash=item2a239c2c2e#shId
Temp:
To temporarily Bypass the slower clock to get the core clock back to normal, use an overclocking tool to change the multiplier back to normal.
Disable Intel Speed Step from BIOS.
or
Windows: http://www.tweakers.fr/cputweaker.html>Change the multiplier. Save.
Linux: Read through>http://techmonks.net/bypassing-the-d...adapter-issue/
Smoblikat
5,184
107
You need to use a bigger power supply for the laptop. Otherwise the CPU will throttle to keep up with the limited power availability.
