- Dec 3, 2006
- 2,284
- 1
- 0
I know a lot of people lower their multipliers to achieve higher FSB's and such, but from what I've learned that doesn't seem to matter on an A64; the major concern is the resulting CPU speed. I've found that a lot of people with lower-end processors (3000, 3200, etc) seem to get high overclock % yields compared to people with 3500's, 3800's etc. Is it because they use a lower multiplier, or is it because the architecture caps out at about 3GHz so they just inherently have that much more headroom? In some instances I even see the lower end ones clock higher than higher ones, not just relative to it's stock speed but the resulting frequency is actually higher. Is it because people with 3000's that get it to OC that high flaunt it and those who don't (the majority of 3000 owners?) just don't, or do most 3000's OC to like 2.6+ GHz? Basically what I'm trying to ask is if lowering the multiplier to that of a 3200 or 3000 give me a higher overclock overall, or will it still cap out at the same speed? If it won't make a difference, then do people with those chips that get in the high 2GHz range just happen to have good OCing chips? My 3500 Venice didn't seem to want to quite hit 2.6GHz at like 1.55v, so I was wondering if lowering the multi would have helped. Also I'm currently OCing an X2 3800, and at the voltage I'm using, ~1.48v, it seems to be capping out at 10x254, so I wanted to know if lowering it to 9 or even 8 would allow me to hit a higher overclock (assuming my motherboard can take it...I know I can boot into windows at at least 285, so lowering it to 9 may be a viable option if it will mean a higher CPU OC).
*Note I know the differences among the cores, but I generally mean among processors with the same core, I have Venice in mind.
