I've been trying to track down a cold boot problem for the past few months.
spec as follows
AMD 2600 barton
asus a7n8x deluxe v 1.4
corsair value ram 512mb x2
geforce 4 ti4200
maxtor 160gb hd
IBM 40gb hd
pioneer dvd drive
liteon 52x cdrw
antech trupower 330w
lian li pc60 aluminum case
swapped out motherboard but problem persist
changed HD, still no dice
which leaves the PSU
ran sandra and mbm 5.0 and got the following #s
Voltage Sensor(s)
CPU Voltage : 1.58V
Aux Voltage : 2.45V
+3.3V Voltage : 1.20V ****
+5V Voltage : 1.37V ****
+12V Voltage : 2.87V ****
-12V Voltage : -16.97V
-5V Voltage : 2.94V
Standby Voltage : 3.28V
Battery Voltage : 3.20V
Not sure if those #s are reliable since my computer is rock stable once it boots into window. Is there another program that can check voltage?
spec as follows
AMD 2600 barton
geforce 4 ti4200
maxtor 160gb hd
IBM 40gb hd
pioneer dvd drive
liteon 52x cdrw
Voltage Sensor(s)
CPU Voltage : 1.58V
Aux Voltage : 2.45V
-5V Voltage : 2.94V
