Low-side AC reading 80+ PSI???
Status
Not open for further replies.
bhanson
Not Fixed. Fuse was blown. :\
I noticed the light wasn't coming on when I pushed the AC button, so once I replaced the fuse that turned back on. The AC started to cool and was blowing cool air, but then started to warm back up again. I measured the PSI on the low-valve and it still reads 80+ PSI.
The air conditioner on my car stopped blowing cool air last Friday on my way home. When I start the car it appears to blow "cooler" air and then slowly degrades into hot air.
I don't know very much about cars, but I figured I could just get away with topping it off with 134a. I have a pressure gauge and I understand the procedure, but when I insert my gauge on the low side the reading it too high for my meter.
Adjusting for temperature (it's about 98 degrees right now) it should read optimally about 50-55 PSI and lower if it needs to be topped off. My gauge only goes to 80 PSI and when I plug it in it pegs the meter.
Is there an explanation for why the low-side gauge is showing so much pressure?
If the compressor isn't running, the high and low sides will equalize - so 80 isn't surprising.
WHAT fuse blew?
WHAT fuse blew?
The fuse marked "AC"--it was the first fuse in the box (top left).
The air conditioner seems to be working now. I haven't tried to recheck the pressure--the valve is in an awful spot and it's really easy to burn myself.
Probably unrelated (I think), but my radiator cracked today and I had to get that replaced. Antifreeze was coming out and hitting the hot engine causing white smoke to appear.
that is your answer. with the compressor off it should be somewhat reading ambient temp.
You could have a short in the compressor thats why that fuse popped. Fuses dont pop without there being a reason for it to be.
Status
