Low resolution with High Quality vs. high resolution with Medium Quality gaming
webmal
Banned
What settings would you guys suggest for playing PC games which provides better GFX quality and a high FPS. Low Resolution 1024X768 with High Quality setting or native resolution 1280X1024 with Medium Quality setting?
My LCD is 17" 1280X1024 native. Thanks.
Shuttle SB61G2v3
P4 3.4GHz Northwood
1GB Ballistix 2-2-2-5
Leadtek 6800 A400
74GB WD Raptor
Sony DRU-530A
Stick with your LCDs native res, it will keep things cleaning (image wise) on your screen, anything other resolution the LCD will interlace it and add a bit of a blur. So, I say stick with your native res and work it from there. 🙂
