Nearly all pre-OBD-2 cars do better with performance exhaust. The dumb OBD-2 computer gets messed up if the exhaust is changed. Or you buy the performance exhaust and get the PCM a performance chip... That's about it.
This has nothing whatsoever to do with OBD-1 vs OBD-2 or anything like that.
Any EFI computer is "expecting" certain flow characteristics for an engine. If you change those flow characteristics, you need to re-map the tables in the EFI computer to account for those changes or else the engine will not run as well as it could.
My own weekend car, for example, is a 1986 944 Turbo. This is well before OBD-1, let alone OBD-2, yet in order to allow it to run properly with my mild modifications, I had to replace the eeprom with one that used tables built to handle the modifications I've made. My EFI Harley (which is also non-OBD-2 as motorcycles are not subject to OBD regulations) likewise required re-mapping the ECU for the engine to run properly after replacing the exhaust and the intake. It would have run very lean had I not replaced the mapping tables with ones designed for the new parts.
OBD-2 or not, if a car is EFI and you do anything that makes a significant difference in the amount of air you can flow through it, you need to re-program the ECU. If you don't, you're running a very large risk of having your mixture off by a dangerous amount.
My camaro is ODB-1 so I got the performance exhaust and K&N performance intake. Hp is noticeably increased and the throttle response is so wicked now.
If there is any significant difference on a dyno (which experience tells me to doubt from just a K&N and an exhaust unless you went all-out with long-tube headers), then chances are you really are in need of a proper tune. I'll almost guarantee that your mixture is off.
My next power boost is going from 16psi to 17 psi injectors while side gaping the plugs. That may be it for me because the engine would redline smashing the pedal down to the floor and holding it then.
Uh... Fuel injectors are rated by flow rate (i.e. lb/hr), not by delivery pressure. Raising the line pressure can increase the flow rate of a set of injectors as long as you're within the acceptable range for the injectors, but if you walked into an auto parts store and asked for "17 PSI injectors" they'd either look at you funny or outright laugh.
Furthermore, 17 PSI is incredibly low for an EFI system. Typical EFI fuel pressure is 35 to 45 PSI at the fuel rail. If your car is only getting 16 PSI at the fuel rail, it's a miracle that it can even idle.
As far as side-gapped spark plugs, that's an old wive's tale. An electric spark will always take the fastest path to ground. You won't get a larger or a more powerful spark by side-gapping your plugs and you won't see any power increase. It's just as much BS as the "+4" plugs or "Splitfire" plugs. A good, old fashioned, copper plug with the proper gap will do just as well.
ZV
