Low Profile GFX Card Help
EduCat
Hi guys,
First off let me say that I was hardly even aware that these low profile cards even existed. I ended up buying a HTPC, low profile case.
I can play games pretty well on the system now, but am looking to possibly upgrade my gfx card.
The cpu is a q8440 core 2 quad, 8 gb ocz reaper. The current card I have in the rig now is a zotac 1gb ddr geforce gt 520. It is a DX11 card but is zotac just value stuff?
Should I spring for something like the Radeon 6750? According the some websites the 6750 is much better than a gt 520, but my zotac box gives me somewhat better specs.
Anyways, any thoughts on the matter? What card should I get? I'm not looking to get the best of the best, just seeing there's something worthwhile out there.
Always appreciated,
Regards
FWIW, this is the page I was referring to when looking for these cards: http://www.squidoo.com/best-low-profile-video-graphics-cards-for-gaming-2011-pci-express
there are some low profile HD 6850 if I'm not mistaken and its the most powerful low profile card you can get.
here are some example :
20456_09_low_profile_hd_6850_graphics_card_from_afox_on_shelves_in_japan.jpg.pagespeed.ce.RjWBRdOOyd.jpg
20456_10_low_profile_hd_6850_graphics_card_from_afox_on_shelves_in_japan.jpg.pagespeed.ce.4LFWh0gvdv.jpg
here are some review about low profile card : ixbt LAbs
Which power supply do you have in your system and how many amps(A) are on the +12V supply?
Also, how much do you want to spend?
I'm not positive what brand it is atm of posting this but I believe it is just a 300watt psu. As far as the amps go I'm not sure, will have to look.
This was one thing that I was noticing, is that generally most of these cards are looking for 400w+. I've been thinking about changing cases to get rid of the low profile stuff but I'm leaning towards just purchasing a card and calling it a day.
I've been debating switching cases but I'm kind of getting used to the small form factor. :awe:
I don't really want to spend more than $125-$150 or so. I'm thinking maybe the HIS Radeon 6670? Looks like a solid card. Thank you for the responses.
With a 300w supply you could get a 5770/5750 low profile card if you could find one for under 150.
Or you could wait for a low profile 7750/7770 if they ever make one, otherwise a sapphire (what I have) or HIS 6670 would be your best bet.
