Low power + modular
Discussion in 'Power Supplies' started by djw39, Jan 8, 2013.
  1. djw39
    djw39 Junior Member
    Nov 3, 2012
    16
    Let's say I wanted to build a modest micro ATX system in the Temjin case. The review said to use a modular PSU or it would get crowded in there. Other articles have stressed the importance of not buying too powerful a PSU if you don't need it (I don't).
    I think it would be either the Corsair CX430M or Seasonic G series 450w. (Rosewill Capstone is actually a bit larger?) As I gather the Seasonic is "better" in some sense...but should I care? Any circumstances in which you would strongly recommend one over the other?
  2. Loading...
    Similar Threads - power modular Forum Date
    Modular Power Supply Standard Question Power Supplies Oct 8, 2016
    Used Antec True Power 650 (Semi Modular) PSU. Should I use it for new rig? Power Supplies Jan 30, 2015
    Corsair CX 430W Power Supply with Modular Cabling Power Supplies Jan 22, 2013
    Do you hate modular power supplies? Power Supplies Apr 13, 2012
    Modular power supply suggestions Power Supplies May 30, 2011
  3. Zap
    Zap Elite Member
    Oct 13, 1999
    22,378
    Buying a more powerful PSU than you need will cost you more money up front at time of purchase, cost you a tiny bit more money all the time (may have lower efficiency at lower loads) and give you that huge wad of cables when not using a modular unit.
    Buying the wattage you need will likely result in you using the majority of the cables, and thus not needing modular.
    Yes, unfortunately the excellent and cheap Capstone PSUs are deeper than the others you mentioned. Seasonic has better quality output and is more efficient than the Corsair, but costs more money. It is also quieter.
    What components will you end up using? Maybe you don't even need that high wattage? Seasonic makes a 360W G series.
  4. lehtv
    lehtv Lifer
    Dec 8, 2010
    11,658
    8
    XFX 450W $45 AR is a decent option, it's quite compact (5.91" or 150mm deep).
    #3 lehtv, Jan 9, 2013
  5. djw39
    djw39 Junior Member
    Nov 3, 2012
    16
    For sure I don't need the wattage, I could get away with the 360W, but that one actually isn't modular. Same for the XFX model suggested by lehtv, Antec Earthwatts 380W, any number of other things. The review of the Temjin case was quite insistent that it demands a modular unit though.
    I guess I ought to look into exactly what cables are included with a small unit like the Seasonic 360W, that may be the way to go if there aren't too many extra cables. If Seasonic is quieter than Corsair that seems a reasonable excuse to spring for it.
  6. Zap
    Zap Elite Member
    Oct 13, 1999
    22,378
    That's because the reviewer either lacks imagination, has OCD or has way more wattage than needed because higher wattage PSUs have more cables.
