I want to upgrade the GPU on my HTPC so it can handle games on my 1080p plasma. I don't need ultra settings, but just want to be able run games like Civ 5 and X-Com (not into FPS games). Here are my current specs:
CPU: Pentium Dual-Core E5200 2.50GHz LGA775
CPU Cooler: Stock cooler
Motherboard: GIGABYTE GA-EP43-UD3L LGA775
Graphics Card: SAPPHIRE Radeon HD 4670 GDDR4 512MB
HDD: Western Digital WD6400AAKS 640GB SATA 3.0Gbps
Memory: A-DATA 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model ADQVE1B16K
PSU: Corsair VX450W CMPSU-450VX 450W
Case: SilverStone Lascala LC17 SST-LC17B ATX
Optical drive: LG Black Blu-ray/HD DVD-ROM & 16X DVD±R DVD Burner
OS: Windows 7 RC
Because of the 450W PSU I'm thinking I should go with a GPU that doesn't use a lot of power. I'm thinking a 650 TI would fit the bill, but am wondering if my current PSU can handle even that, or if there's anything with better performance that will work with my PSU. I should mention that the computer has an extra 3 WD green hard drives for data. These drives don't draw a lot of power, but I mention them just in case they would make a difference in what GPU to go with. My budget for a new graphics card is $200 tops.
OS: Windows 7 RC
