- Dec 29, 2005
- 2,046
- 36
- 101
Hi all,
I plan to build a 4 PC gaming rig based on the midrange build:
http://forums.anandtech.com/showthread.php?t=2192841
I realized the power consumption for that is going to be VERY high? I never bought a UPS for 4 PCs before.
My circuit breakers also come under concern. I have a 240V 30amp breaker pair I was going to break up into two 120V breakers, use one of them for the UPS - and the other for the rest of the room. Now it seems like I won't be able to find a single UPS that will work on a single 120V breaker to properly supply power to 4 PCs meant strictly for gaming?
So the question is, what can constitute a LOW power requirement gaming rig? The 7970 in that build thread is probably too high in consumption. Typically the higher powered cards are for gaming, so now it's difficult to solve this problem.
For example, recommend I use SSD instead of hard drive (that sort of thing). How can I keep the power consumption of each PC low?
Thanks!
ELmO
Thanks!
ELmO
