- Dec 11, 2001
- 418
- 0
- 0
Hi, I was wondering how I would perform a low level format on a western digital drive. I couldnt find a utility to do it on their website. Thanx for your help beforehand.
Calvin
Calvin
Originally posted by: yellowperil
I've used the WD software to zero-fill my WD 60GB without any problems. The disk was created in WinXP and all my partitions are NTFS. All you need is the Diagnostic utility from this page.
This is what it says in the description for Data Lifeguard v2.8:
Note:
The Data Lifeguard Tools diagnostic utility can be used to test a drive that has Windows NT, 2000, or XP installed on it. However, you are unable to create the Data Lifeguard Tools disk from a system running Windows NT, Windows 2000, or Windows XP.
I tried it and was unable to create the disk in XP, I get an error when it tries to write to the floppy. So I'd be interested in hearing how you managed to create this disk in XP, if you are indeed talking about the same software.
