Low Level Format Utility - Suggestions?
mplutodh1
305
What's my best bet on a low level format utility? I am RMA'ing a drive that is all whacked out and want to get as much of the data off of it as possible. It's a SATA Maxtor that I am running in my office box.
jonnythan
130
Powermax will erase partitions, and a format will overwrite data, but after a Powermax session most data recovery utilities will still be able to get a large amount of data off the hard drive.
Killdisk is a fantastic small utility that provides exactly what you're looking for. Secure data removal.
mplutodh1
305
Problem is Powermax wont work with a RAID controller on my board, and I dont have access to another system to take care of this.
mplutodh1
305
RAID is turned off but the SATA connectors are through a RAID controller built into the board. No way around it as far as I know.
jonnythan
130
Have you tried Killdisk?
I've used it on SCSI drives attached to a PCI RAID controller. I'd be surprised if it couldn't handle SATA.
mplutodh1
305
thanks guys, actually just used killdisk. It appears to have done the trick, i only ran it at level 1 security though because it took forever on a 300g drive.
Before I send this sucker off for RMA, anyone know of a way to truely check the health and see if it was just some fluke? As mentioned, the Maxtor utilities wont work through the controller.
