Originally posted by: cuti7399
yes, bios is ok. jumper was set to 32gb but i moved that to the right position now but even after the low level format it is still a 32g drive!!!???
Does HUTIL still read the drive as 32gb? (It shouldn't)
You should run the utility again and repartition or zero-write (really a quazi low-level format).
This is assuming that your motherboard bios supports >32gb
Samsung has 2 utilities. I can't remember which one does which though. Between the 2 of them you should be able to get the drive ready for full capacity.
BTW- if you don't want to have to search out the different utilities for hd's etc...
You should download and burn the ultimate boot cd.
link
It has diag and utilities for all the major hd manufacturers as well as memtest86 and prime95 etc...
