- Oct 11, 1999
- 1,924
- 0
- 0
I recently upgraded my 32 MB GeForce2 GTS to a 64MB PNY Ti4200 card. I was hoping that I would get some better performance in UT2k3, unfortunately, that isn't the case. My FPS is low, nothing every reaching over 35 or so and on average I get in the mid-20s. Here is my syststem:
950Mhz Athlon
512MB RAM
KT133 motherboard with the latest VIA 4in1 drivers installed and I am using the latest Geforce drivers for Win2000.
(nothing overclocked)
I neither have AA enabled, nor do I have anisotropic filtering enabled. Vertical sync is off, as well. I have everything in the NVDIA drivers tab set to performance, but that doesn't seem to do much for me. I have tried running the game @ lower res, but that doesn't change a lot. I have also played with the settings in the game and I can't see a huge difference either.
Any thoughts? I have a fresh install of Win2000, so I don't know what's up. Is there something in the bios that I should enable/disable to increase performcance or I'm I just seeing the limitations of a slower CPU?
950Mhz Athlon
512MB RAM
