- Dec 25, 2014
- 4
- 0
- 0
Hello, I just completed a new build, and have been experiencing issues. In all of the games I try to play, I keep getting low framerates (nothing above 30) despite my attempts to raise or lower graphical settings. I have tried Skyrim, Fallout, Metro LL, and Crysis 3 so far with no luck. I am also not sure how hard my cpu should be working when sitting at the desktop.
My Specs:
CPU: AMD FX-8350 - Factory Clock (4 GHz) w/ Stock Cooler
GPU: Zotac Nvidia GTX 970 4GB
MOBO: Asrock Fatality 990fx Killer Motherboard
Storage: WD Red 3TB HDD & Samsung EVO 120GB SSD
RAM: 8GB Team Vulcan DDR3 1600 MHz
PSU: Rosewill ARC 750W
OS: Windows 8.1
I've been scouring the web and it seems like others are having issues with their GTX 970 cards, experiencing extremely low fps for what should be a decent card, so I thought that might be the problem. I play at 1920x1080 resolution, and can't even get higher than 30 fps in fallout, which I was able to do on my old build with a Radeon 6870.
I also tried removing the stock cooler for my CPU, and reapplied the thermal paste, but it did not help at all. I know that AMD processors are not as good at single thread/core processes when compared to Intel, but In didn't think that it made this big of a difference. If anyone could offer help I would greatly appreciate it
My Specs:
OS: Windows 8.1
