interchange
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
I'll be doing generally web browsing. I'll also be doing some programming in NetBeans IDE. Also will be doing some office work, but not a whole lot and don't need genuine office. Will be using citrix to remote to different work sites, which can be a memory hog. I don't do any gaming any more, so on-board video should more than suffice.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
All-in budget is $500 including OS & monitor
3. What country YOU will be buying YOUR parts from.
USA
Friday/Saturday are also no-tax day so in-store deals @ Microcenter would be great; also will do things on-line as needed. No urgency to get everything together.
4. N/A
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Nope. Not a fanboy here.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I have an optical drive + mouse/keyboard. I have a monitor but will be looking to upgrade this. Possibly use it as 2nd monitor.
7. IF YOU plan on overclocking or run the system at default speeds.
Doesn't matter to me. If there's a setup that's overclock oriented and saves me $ for same performance, I'm game.
8. What resolution, not monitor size, will you be using?
Don't have a monitor so it doesn't really matter. Whatever native resolution on a 20" range LCD is fine.
9. WHEN do you plan to build it?
Within the next couple of weeks. Again, end of week would be a good time for me to pick up local deals -- no sales tax.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Yeah. I need an OS. Probably windows 7, but if anyone wants to convince me to try 8.1 I'm listening.
USA
4. N/A
