Low-End Build
piasabird
17,168
60
I recently put together a low-end Mini-ITX build and thought I would share. Since I already spent the money, it is to late to make changes. In fact I already got it running with the OS Installed on a hard drive.
Case: Thermaltake V1
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133260
Power Supply: Corsair CX430
http://www.newegg.com/Product/Product.aspx?item=N82E16817139026
Motherboard: Gigabyte GA-H110N
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128899
CPU Intel i-3 6100
http://www.newegg.com/Product/Product.aspx?Item=9SIA1UH3Z96233
Hard Drive $45?
DDR4 Single 8GB Gskill Aegis 2133 Similar to this. Added second one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820232248
Wireless Adapter: Edimax 600
http://www.newegg.com/Product/Product.aspx?Item=N82E16833315132
OS: Microsoft Full Retail on USB
http://www.newegg.com/Product/Product.aspx?Item=N82E16832588528
Feel free to make comments if you want to.
For some reason I decided to try ordering just one stick of DDR4 in 8GB size. I reasoned that if I want 16 it would be easy to order one more stick of RAM.
I saved some money by ordering the Motherboard and CPU at Micro-Center. I was going to buy a lower-end Pentium dual core CPU but they had a deal where you could do a combo deal and save $30 on the motherboard. I did end up spending $15 in tax. However, I have noticed a lot of places on the Internet are charging tax now.
I love that ITX case. it is so easy to work on because even the bottom can come off to get at the power supply. Just remove 2 thumb screws and it comes off. It has a 200mm front fan and room for two more 80 mm fans in the back. The front of the case lets you extend your video card out to the wire mesh front grill.
Warning this is a video on youtube?
Reactions: monkeydelmagico
Ken g6
Moderator
Dec 11, 1999
16,843
4,823
75
I would not suggest that unless you really plan to buy that second stick soon. Especially without a discrete video card, that i3 needs RAM bandwidth.
nerp
9,867
105
Definitely do dual channel. And please, get an SSD, not an HD. That is the key ingredient to making a cheap build really zippy.
Good CPU choice.
piasabird
17,168
60
I planned on getting one more stick of ram. I took a photo of the part numbers just in case. I might get an SSD later around XMAS. The EDIMAX USB AC600 dual channel network adapter is really working well.
piasabird
17,168
60
I updated my monitor. The one in the photo is a Dell 18.5 HD Monitor. That was a bit small So I am using a 32" Samsung HDTV as a monitor. It worked pretty well but it does not fit the video well to the screen size. I had to do a custom aspect ratio in the Intel graphics display options for the i-3 IGP to work right. This could be the HDTV or the Intel IGP not wanting to work well together.
Samsung UN32J5003AFXZA 32-Inch 1080p HD LED TV - Black (2015)
http://www.newegg.com/Product/Product.aspx?Item=N82E16889354950
I purchased this item at $197.99 with free shipping. It has a slightly higher price now.
