M mshan Diamond Member Nov 16, 2004 7,868 0 71 Sep 13, 2007 #1 How can I determine of a 256 MB PC133 SO-DIMM is low density? How many individual memory modules should there be per side? And should there be memory modules on both sides of the SO-DIMM? -------------- Moved from GH JackMDS GH, Moderator
Dahak Diamond Member Mar 2, 2000 3,752 25 91 Sep 13, 2007 #2 generally the lower the density the more chips on the stick, and if i remember right the max would be 4 or 8 per side. the other way to to google the chip part number that is on the chip it self and it should give you the density as well
