Low cost but reliable light duty web host?
etherealfocus
488
13
I run a side business building and webmastering local small business websites. Been using 000webhost.com for years now but uptime has become a serious problem recently. I never even bothered buying their paid hosting because the free hosting worked fine, 99%+ uptime consistently. Within the past month it's dropped to more like 80-90% uptime.
I'm totally fine with the $5/mo for their paid hosting, but don't wanna waste money if it's not gonna fix my problems. They claim it will... but I'd rather second some second opinions. Stick with 000 or is there a significantly better cheap but reliable option? I'm mostly just hosting simple hand-coded XHTML sites, don't need anything but the basics.
zCypher
6,115
171
Go with madgenius of course, but if not check out hostgator. used them for a while, cheap and worked fine ($3).
etherealfocus
488
13
Rossman - $6 is fine - show me the business case and if the ROI is good I'll take it.
I'm leaning toward madgenius; always nice to do business with another ATer. I'm really not sweating a buck or two a month, but of course no point in buying stuff I'll never use.
So just to make it easy - Rossman, if you can offer a few bucks a month worth of benefits over madgenius, I'm yours. :)
etherealfocus
488
13
prmgr looks cool, but perhaps a bit more complexity than I need. Nothing from Ross yet so I'm rolling with MadGenius. Thanks guys!
MarkXIX
2,642
I prefer Cirtex Hosting. I pay $2.50/mo. and I have been happy with it.
etherealfocus
488
13
Have to say, I'm happy with MadGenius so far. Forgot to enter the coupon code, but I already bugged support with a couple dumb questions that turned out to be entirely me brainfarting in both cases, so I'll just call it even at that. :)
I'm sure I'll make far more than my lost 30% on the referral program anyway lol
Elixer
10,371
762
What about a medium duty server ?
Is there a good cheap hosting company that provides root access for a open source project ? They run the usual stuff, forums, bug tracker, and custom web applications for the project.
Server needs to have at least 8GB RAM, quad core, and at least 200GB HD.
I believe the current provider they use charges $65/month for above specs) but that is too much for them to maintain, and their donation drive for the past year hasn't generated much to help offset the costs.
Oh, they are based in Europe, but I don't think it makes a difference where the server is.
RossMAN
Grand Nagus
Feb 24, 2000
79,030
438
Unfortunately Europe bandwidth, power and data centers are expensive.
Does it have to be in Europe? Is USA ok?
Would a VPS (Virtual Private Server) be sufficient?
