Low 3dmark2001.... what the hell is going on
Mister T
3,439
Project Name My Benchmark
Operating System Microsoft Windows 2000
DirectX Version 8.00
Mobo Manufacturer
Mobo Model
CPU AMD Athlon(tm) Processor 1002 Mhz
FSB Unknown
3D Accelerator NVIDIA GeForce3
Graphics Chipset NVIDIA GeForce3
Driver Version 5.13.01.1241
Video Memory 64 MB
Resolution 1024x768 32bit
Texture Format Compressed
FSAA Disabled
Z-Buffer Depth 24bit
Frame Buffer Double
Rendering Pipeline D3D Pure Hardware T&L
3DMark Result 1676 3D marks
Game 1 Car Chase - Low Detail 28.0 FPS
Game 1 Car Chase - High Detail 10.4 FPS
Game 2 Dragothic - Low Detail 18.0 FPS
Game 2 Dragothic - High Detail 6.8 FPS
Game 3 Lobby - Low Detail 35.4 FPS
Game 3 Lobby - High Detail 16.1 FPS
Game 4 Nature 9.0 FPS
Fill Rate (Single-Texturing) 586.7 MTexels/s
Fill Rate (Multi-Texturing) 1321.6 MTexels/s
High Polygon Count (1 light) 1.8 MTriangles/s
High Polygon Count (8 lights) 1.7 MTriangles/s
Environment Bump Mapping 67.2 FPS
DOT3 Bump Mapping 66.4 FPS
Vertex Shader Speed 5.9 FPS
Pixel Shader Speed 46.6 FPS
Point Sprite Speed 3.2 MSprites/s
Published No
ConFuseMe
40
Thats an extremely low score, you should be getting at the least 6000.
What motherboard do you have and what chipset?
I have the same problem with my GF3 Ti200, which turned out to be a Via Chipset issue...
I'm not saying thats your problem, but someone with a GF3 doesn't get a super low score like that for no reason.
Being the Platinum member you are, you probably checked the obvious, so I figured I'd say one of the least obvious. :)
Ah what the hell, I'll state the obvious anyway.
Update to DirectX 8.1, and get the latest drivers for your card. If your using your card manufacturers drivers (which it looks like you are)then try the latest Nvidia drivers version 23.11. Make sure your video card isn't sharing an IRQ with another device. To help insure that your video card runs smooth it should be on an IRQ channel by itself.
Also to help people respond you should post your system specs, what you changed in your system recently (new hardware added, ect), and tell us if this is just a 3d mark problem or if you get bad FPS in every game/program.
Thats my two cents.
DClark
430
Considering that it's not recognizing the motherboard manufacturer, model, or fsb speed, I'm guessing that you just need to re-install your motherboard drivers. It's possible that during the rebooting process of installing the motherboard drivers that it may have aborted installation or had some sort of error on installation.
Mister T
3,439
Ok, thanks for the input guys. I think I need to install some more drivers....
The mobo is a MSI K7T Pro2-A ..... I think - I don't know if its the "a" version or not.
I have 384mb RAM
Geforce3 is a gainward cardexpert
Assuming I were to reformat everything and install the OS from scratch, what drivers do I need to install?
-- Latest Nvidia
-- Direct X8.1
-- What mobo drivers do I need? What is the 4 in 1?
Also, how do I check if there are any mobo specific drivers installed... I think its just using the drivers that win2000 has.
Is that what is f-ing everything up?
What kind of score should I be getting with a 1ghz T-bird + G3 + 384mb Ram?
ConFuseMe
40
Ok, it looks like your board runs off of the Via KT266A chipset.
Here's the boards that matched what you said at MSI's website.
http://www.msicomputer.com/product/chipset/via_kt266.htm
So for your motherboard drivers you'll need to get the latest Via 4in1 drivers v4.36. You can get that here. http://www.viaarena.com/?PageID=2 .
The 4in1 drivers work on any Via Chipset motherboard and on any windows platform.
For any additional mobo help here's the link to the MSI support page in case you don't have it allready.
http://www.msicomputer.com/support/msisupport.htm
Another thing I thought of is that if there is a sound card or any pci card in your motherboards PCI slot 1 then move it to another pci slot. Someone recently told me that the PCI slot 1 and your agp slot usually share the same IRQ and that can suck resources away from your vid card, which would make it run slower.
As for what you should be looking for in your 3DM score, I estimate you should be getting 5500+. Anything lower would be considered poor performance on that system.
Mister T
3,439
ConFuseMe,
I just installed the 4 in 1 drivers and my score went up to 5431.
Also, my mobo is not does not have a 266 chipset..... It has the KT133A.
Here is the printout.
Still need to update directX...
Thanks for all the help :)
Mobo Manufacturer
Mobo Model
FSB Unknown
Driver Version 6.13.10.2311
Video Memory 64 MB
FSAA Disabled
Frame Buffer Double
[/b] 3DMark Result 5431 3D marks [/b]
Game 1 Car Chase - Low Detail 83.9 FPS
Game 1 Car Chase - High Detail 27.2 FPS
Game 2 Dragothic - Low Detail 87.8 FPS
Game 2 Dragothic - High Detail 49.4 FPS
Game 3 Lobby - Low Detail 83.2 FPS
Game 3 Lobby - High Detail 36.9 FPS
Game 4 Nature 30.0 FPS
Fill Rate (Single-Texturing) 648.4 MTexels/s
Fill Rate (Multi-Texturing) 1331.8 MTexels/s
High Polygon Count (1 light) 15.7 MTriangles/s
High Polygon Count (8 lights) 3.1 MTriangles/s
Environment Bump Mapping 105.2 FPS
DOT3 Bump Mapping 105.4 FPS
Vertex Shader Speed 42.8 FPS
Pixel Shader Speed 74.0 FPS
Point Sprite Speed 14.8 MSprites/s
Published No
ConFuseMe
40
My bad.
I just put in a search for the motherboard you mentioned and it came to that page so I assumed it was a 266. :)
As you can tell I'm not a pro, just started really learning about computers myself a few weeks ago.
Glad I could point you to the drivers at least....
I guess you just had outdated via drivers.
