Low 3dmark06 scores
Hellotalkie
1,615
I tried the 3dmark06 with my 7800gt and I think I got a low score. There are no power issues or cooling either. I also can get down to around 30fps in css and thats definately not normal, should I rma the card through evga, since its lifetime warranty.
myocardia
9,291
30
That all depends on how fast your processor is, and how much memory you have.
edit: It also depends on what you scored.;)
videopho
4,185
29
The "low" score does't mean much if we don't know squat of what's the remaining of your system's config looks like?
happy medium
14,387
480
I score 3323 with my setup in "06"
So it looks about right.
You need to overclock your 7800gt. With my over clock my 7800gs is probrobly just as fast.
what setting are you using in the css test?
I'll run the same settings and we'll compare
Crescent13
4,793
That sounds about right.
I get about 3700 with my Oc'ed 7800GT, 2.8GHz Opty 144, 2GB PC-5000 ram, and drivers set to max performance.
videopho
4,185
29
That's a bit low for your system. Should try to o/c a little to see if you can get close to 4000. Even with my Dell (Pentium4) with o/c the 7800gt, I've got about 4000 with it.
