- Aug 21, 2002
- 18,368
- 11
- 81
I have a HP DL380 and a backup to disk appliance.  Both use Intel X520 10GbE adapters and are directly connected via fiber.
I ran a test using a utility that generates a random file on what ever destination is specified, so it takes source disk out of the equation. Running the test locally, I can see that the local physical disk on the DL380 is capable of writing at about 400 MB/sec. When I ran it against SAN attached disk, I was able to write at about 500 MB/sec, which is the limit of the 4 Gbps fiber channel HBA's we use. When I ran it against the backup to disk appliance via the 10 Gig Ethernet connection, it was only able to write at about 330 MB/sec. The vendor says the disk subsystem is capable of ingesting over 1000 MB/sec, so I should be able to almost saturate the 10GbE NIC, but I can't. I even tried multiple streams of data.
At the manufacturer's request I ran iperf and tweaked TCP window size and achieved a maximum of 440 MB/sec, which is better, but still less than half what the connection should be capable of.
Anyone have any experience tuning/troubleshooting 10GbE performance?
