- Jul 29, 2005
- 86
- 0
- 0
Hey all,
I just put in my 6800GT from Leadtek and everything was going fine at first. After a while though, there was a terrible noise coming from the case which turned out to be the 6800GT fan. I thought it might be the chipset fan since the MSI boards have had some problems with that, but I'm pretty certain it's the video card. Only after letting it cool off a while did the fan go back to its initial silent operation, but when it heats up again the RPM must go up and the fan gets loud. And when it gets loud, it gets really loud. It drowns out the noise from all 5 other fans in my case.
I did search the forums and only found one post from a while ago with the same problems so it looks like it's not happening with most cards. Anyone else have this problem and fix it? I'm trying to decide whether I should:
1) Try to fix it myself if anyone has any ideas
2) RMA it to Newegg and wait another couple weeks to use my comp
3) Buy an aftermarket HSF for the card (suggestions?)
Let me know your experiences and opinions on this. Thanks.
