- Nov 5, 2001
- 18,366
- 3
- 0
I put new pads on the rear calipers of our car a while back, and when I brake pulling out of the driveway or in other low-speed situations, I can hear a rubbing/grinding sound. These are semi-metallic pads, and I used a pad grease. The shims from the OEM pads didn't seem to want to fit the new pads, which had a thicker plate on them, so I elft the OEM shims off the replacement pads.
The rotors were a little grooved but due to time constraints and weather, I didn't undertake that job.
Could leaving the shims out be the issue? Could it be the rotors? I know semi-metallic pads can be a little louder, but this seems to be a little louder on the passenger side, and is pretty loud so I'm a little concerned it's not normal.
