- May 4, 2002
- 3,345
- 32
- 91
Using HDMI, and running the TV's headphone out to a headphone amp produces major noise at even the lowest volumes. Using just the headphones from the TV sounds fine. Using the 360's Component cables and RCA audio directly to headphone amp sounds clean and beautiful.
Is there any way I can use HDMI and the headphone amp at the same time? Is there something in the middle causing interference? Without the amp the TV's headphone out sounds fine.
if that's hard to understand, here it is:
360+Amp+TV out = noise
360+TV out = no noise
360+Component cables+Amp+TV = wonderful, but I like HDMI.
Edit: Specs in case they are needed:
Xbox 360
Evilfire Cmoy
Beyerdynamic DT 660
Sony Bravia
Xbox 360
Evilfire Cmoy
Beyerdynamic DT 660
Sony Bravia
