Lots of INCOMING connections on port 6881
episodic
11,088
Just curious what is this? Everything I look up about this port mentions you should open it for bittorrent, but in my case I have multiple people making hundreds of attempts to connect to this port. I've never used bit torrent.
Thanks!
n0cmonkey
42,936
If you don't have anything on that port, you shouldn't worry. If you have DHCP someone probably had your ip address previously and had a bt connection going.
episodic
11,088
No I've had this same IP for a long time. If I'm reading this right, this guy's port 65210 is trying to connect to my port 6881 (tell me if I am reading this wrong). Itis being blocked, I just was curious what it was. (The IP's were before the port, I edited it out).
1,[07/Jun/2004 00:03:36] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:65210]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:03:39] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:65210]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:03:45] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:65210]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:03:57] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:65210]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:06:35] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:63952]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:06:38] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:63952]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:06:45] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [63952]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:06:56] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:63952]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:09:36] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:63942]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:09:39] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:63942]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:09:45] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:63942]->localhost:6881, Owner: no owner
1,[07/Jun/2004 00:09:57] Rule 'Packet to unopened port received': Blocked: In TCP, p508E2F27.dip.t-dialin.net [:63942]->localhost:6881, Owner: no owner
n0cmonkey
42,936
You are correct. Don't know what it is. If you don't have 6881 open, not much reason to care. ;)
Diaonic
305
TCP port list
Here is a common port list for tcp/ip it was last updated june 2nd 2004, so its pretty current. This might help you understand some of the common ports that get hit time and time again.
Nothinman
30,672
6881-6890 are the default ports for BitTorrent. If you don't use it and don't have anything listening on that port I wouldn't worry about it.
JackMDS
29,552
429
Relax and try to forget about it.
Been concern about this is like standing in your home by the window looking at the cars passing by, and asking why all of these people are passing by? I do not like it!
Internet traffic passing by your door (port). The Ports are closed, enjoy life.
:beer:
episodic
11,088
Ahh, I don't usually worry about it, and was more curious than anything :)
I like to know motivations behind certain port scans, and this one just seemed 'stupid'.
