VirtualLarry
Ok, I have an Asus B450-F ROG STRIX ATX mobo here.
Ryzen R5 3600 CPU, water-cooled with 240mm AIO CM WC kit.
16GB GSkill RGB DDR4-3600 "for AMD", CAS-18-22-22-xx, 1.35V. Running FCLK 1800 to match DRAM.
2x 1TB Intel 660p PCI-E 3.0 x4 NVMe SSDs, in both M.2 sockets, running in RAID-0, CSM disabled.
Not overclocked on CPU (other than FCLK).
Had an MSI Ventus GTX 1660ti in top GPU (PCI-E x16 slot).
Had a Sapphire RX 470 4GB in bottom GPU (PCI-E x16 slot).
Had an Asus 10GbE-T PCI-E x4 NIC in lowest PCI-E x16 (x4 electrical) slot.
Everything worked, at that point. I could use my 10GbE-T NIC, I could mine on both GPUs, everthing work OK.
Fast-forward to today, I received my second MSI Ventus GTX 1660ti card.
I pulled the RX 470 out, and put the second Ventus into the second GPU slot.
BLAM! My 10GbE-T NIC no longer showed up, at all, not even as a "Code 10 - Cannot start", or "Unknown Device" in Device Manager.
It simply doesn't show AT ALL.
I was on 1.0.0.3AB, flashed 1.0.0.3ABB, still no joy, same as before.
When I installed the second Ventus card on the bottom PCI-E slot, I didn't remove the Asus PCI-E x4 NIC. But then I tried removing it and re-inserting it, if it got jostled or something. Still no dice.
So, I recall, that NVidia's standard for SLI, requires PCI-E x8 support for both GPUs. Only, these GPUs don't support SLI.
My understanding of the PCI-E layout for this board was thus:
CPU: PCI-E x16 lanes, split (x8) top GPU slot, (x4) bottom GPU slot, (x4) secondary PCI-E 3.0 NVMe slot, along with the dedicated PCI-E 3.0 x4 for the primary NVMe slot.
Then the PCI-E x1 and bottom-most x4 slot, were all PCI-E 2.0 off of the B450 chipset, and that plugging in any x1 slot would take away from the x4 electrical bottom PCI-E x16 slot.
So, I thought that I was good to go, and I was, everything was working, with both the original Ventus, the RX 470, and the Asus PCI-E x4 NIC.
My current working theory, is, that the x8 SLI requirement, is hard-coded into NVidia's drivers or BIOS or whatnot, and it's somehow "stealing" 4 more lanes, and running at x8, and not x4, in the bottom-most GPU slot.
That, or my Asus PCI-E NIC mysteriously died upon reboot, somehow. 🙁
Edit: Downloaded newest GPU-Z, 2.25.0, ROG skin (to match my mobo), it shows "Nvidia SLI: Disabled", AND WON'T LET ME SELECT THE SECOND CARD AT ALL!
There appears to be NO WAY in GPU-Z to select the second card, for some reason. What is going on here? I wanted to check the PCI-E width.
