Lost Lan port
lupi
32,539
260
Asrock z68 Extreme4. Just changed out the GPU and after reboot I no longer have a working lan port. Not lights on the port, diagnostics say plug cable back in and substituting a different cable has no effect.
AnonymouseUser
9,943
107
Reset CMOS and see if that helps. Make note of any custom settings in the BIOS (eg, overclocking) so you can reconfigure afterwards.
AnonymouseUser
9,943
107
Google shows lots of problems with that board and LAN, some suggest a conflict between USB 3.0 and LAN. Avoid using any USB 3.0 ports and see if the LAN port works.
lupi
32,539
260
I saw a somewhat related thread someone asking about intel drivers....I used DDU to clean nvida, amd, and intel before swapping cards and wonder if something intel related got screwed up. Looking now for a download.
