Lost and Found program, Help?
Daniel
3,813
I used this powerquest lost and found software what feels like years ago to recover some info off a corrupted drive. After a long story I have a backup hard drive (6 gig) that had a 3 part ghost image on it and it got quick formatted by accident.
Now when I go to use this software, first it hits a part when using the 2nd floppy that it gives a error, not sure if it's related to the problem or not. Secondly, it shows both drives, my 6 gig backup drive, and my 20 gig normal drive that I want to dump the recovered files to. When you select the source drive it allows you to chose either one, but when you go to select the destination drive it only allows you the 3.5 floppy drive, no other hard drives. It sees them both but won't allow you to pick one of them as the destination drive.
Anyone have any ideas since I really could use that info?
thanks,
Daniel
